Vought F-4U Corsair, w/ electric retracts, landing lights and complete extra plane
My Feedback: (15)
Located in Marietta, GA 30064
2 complete Century Jet Corsairs. One ready to finish with a DLE 120 installed and all servos installed, the other to use as you wish.
This 1/5th scale WWII prop aircraft has been designed with the connoissuer in mind. The F-4U is constructed using epoxy, fiberglass and nomex honeycomb to make the lightest and strongest model possible. A scale master aircraft.Composite Fuselage With Panel LinesRemovable Composite gull SectionPlug-in Composite Outer Wing Panels With Panel LinesSix Composite Flaps. Ready to Install.Composite Gear Doors. Ready to Install.Composite Ailerons. Ready to InstallComposite Horizontal Stab and Elevators With Panel LinesHeavy Duty Fiberglass Cowl With Cowl Flaps ExtendedRetract Door Sequencing KitScale Functional Cowl Flaps Scale Exhaust2 complete Century Jet Corsairs. One ready to finish with a DLE 120 installed and all servos installed, the other to use as you wish.
Electric retracts with landing lights and gear doors
Thermal cowl flaps electronics73032 F4U Painted Master Cockpit with Pilot Retractable CanaopySimple to install and operate with two standard servos. The system includes a fiberglass canopy frame, 2 brass horizontal rails, 2 brass front canopy supports, 1 brass square rear canopy guide, 2 aluminum inserts, 8 screws, 2 2-56 rods, 2 wood arms and wood mounts, instructions, and photo brochure.
SPECIFICATIONS:Wing Span: 100? Length: 80?
Scale: 1:5
Engine: DLE 120Standard Cowl Diameter: 8 3/4? x 11 3/8?Special Cowl is 8 3/4? x 11 3/4?Weight: 45 pounds
