Eflite Habu 32
My Feedback: (8)
Eflite Habu 32
I have an E-Flite Habu 32 for sale. Add your receiver and battery and it is ready to go. You will need a receiver and you will need a 6 cell, 5,000ma lipo battery pack. Plane is in very good condition as can be seen in the photos. The only "damage" is a small scuffed area on the bottom of the nose; purely cosmetic. There is a very small area on the bottom of one of the flaps at the trailing edge where the covering shrank back a small bit exposing a thin sliver of balsa. covering is tight and not a problem in that area.
Easily more than $1,000 dollars went into this plane!
Sorry but I absolutely cannot ship this plane. Local pickup in the metro St. Louis area only.
Payment must be either PayPal or cash.
This plane is equipped with all the JR servos that are recommended in the manual as well as the motor and fan recommended by the manual.
Custom Pilot from Aces of Iron.
Dynamically balanced fan rotor.
Manufacturers specs:
Approximate Flight Time: 4.5 minutes
Control Throw (Ailerons): Low: 7mm Up/Down, 10% Expo; High: 8mm Up/Down, 15% Expo
Control Throw (Elevator): Low: 8mm Up/Down, 10% Expo; High: 10mm Up/Down, 5% Expo
Control Throw (Flaps): 11mm take off and cross wind landing; 25mm landing
Control Throw (Rudder): Low: 15mm Left/Right, 5% Expo; High: 20mm Left/Right, 12% Expo
Flaps: Yes
Flying Weight: 7.40 lb
Motor Size: DF 32 Brushless Motor, 2150Kv
Recommended Fuel: Electric
Retracts: Optional
Speed Control: 80-Amp brushless
Wingspan: 40.5 in (1030mm)
Here is a link to online information about this fine flying jet:
https://www.horizonhobby.com/product...df-arf-efl8075
Flaps: Yes
Retracts: Optional
