Jettronic Low Loss Proportional Brake Valve
Jet-Tronics Low Loss Proportional Brake Valve
Revolutionary new brake valve from Jet-Tronics, that allows you to apply your brakes in a near fully proportional manner without the high volume air loss often experienced by other makes. The Jet-Tronics Low Loss valve uses a pressure regulation method, not PWM to control brake application providing far less air consumption and the ability to pre-apply brake during landing approach.
USE LIKE NEW!
- Supply voltage 3.5V - 7.5V
- Current consumption Minimal: only during pressure cahnges max. 200 mA
- Pressure range 0 - 10 bar
- Dimensions (L/W/H) 27 x 29 x 30 mm (without connectors)
- Weight 32 g
- Connectors Universal connection 2.5 - 4 mm tubes (outer diameter)
USE LIKE NEW!
