Actuonix l12 linear actuator
L12-R Micro Linear Servos for RC & Arduino
The L12-R series of small linear servos operate as a direct replacement for standard rotary servos. They use the same standard 3 wire connector, ground power and control. Regardless of how you drive your servos, be it with an RC receiver, an Arduino board, or a VEX micro-controller, the L12-R servo will function in place of a regular rotary servo, but gives you the added benefit of linear motion.
Our L12 line are constructed using an anodized aluminum shaft, metal gearbox, brass screw and steel ball bearings. These quality linear servos are not only built to last, but will look great on your models.
Depending on the stroke length that you choose, the L12-R has a mass of between 34g-56g. It's small size and light weight make the L12-R ideal for airborne RC models, as well as robotics and RC projects.
- stroke lengths 50mm
- 3 gearing options for maximum forces between 22N (5lbs) and 80N (18lbs) and maximum speeds between 6.5mm/s and 25mm/s
- Available in 6V only to ensure compatibility with RC receivers
