35% Pilot RC Extra 330SC 107" WS, DA 120, JR
FL
I have here a brand new 35% Pilot RC Extra 330SC that still needs final assembly with a brand new DA 120 that has never seen fuel. Have a look at my 100% positive feed back and purchase with confidence. There are more pictures in my gallery. Local pick-up is preferred considering it's size. Below is a list of what's included in the sale.
Plane $1,049.00 +62.94Tax $1,111.94
Shipping on plane $175 plus $50 for residential $225.00
Wing Bag $100.00
DA 120 $1,199 +$71.94 Tax and $50 shipping $1,320.94
Smartfly Power Expander EQ10 $249.00 Tax and shipping. $268.94
Smartfly Turbo Reg $84.96 + Tax 5.65 $90.61
4) JR 8411 Servos at $114.99 $459.96
4) JR 8611 Servos at $124.99 $499.96
SWB two servo tray $119.95 + $7.20 Tax $127.15
DA Headers 70mm Drop 140+tax $150.00
Pilot head Hanger 9 $50.00
$4254.50
•DA-100 & DA-120 Engines Require a 70mm Drop Header
•Strong Light Weight Construction
•Professional designed for 3D and precision aerobatics
•Professionally covered in Oracover(Ultracote) from Germany
•Fuselage is set up for canister or pipe installation
•Cowl with cowl ring. No exterior screws exposed
•Complete hardware included
•Removable wings, stabs & rudder
•All control horns included
•Hub wheels included
•Laser cut engine mounting templates
•Carbon Fiber Accessories Included
•Carbon Fiber wing tube
•Carbon Fiber tail wing tube
•Carbon Fiber landing gear, Painted to match the color scheme
•Carbon Fiber tailwheel
•Carbon Fiber spinner, Painted to match the color scheme
Pre-Installed Components•Hinged wings and stabs
•Hinged Fin and Rudder
•Installed fuel tank
•Mounted and painted Canopy
•Drilled servo control horns with translucency color
•Installed pull pull wire with ball links on rudder
•Installed push rods with Ball links
Pilot RC Brings Customer Service to a Whole New Level!
Free wood part replacements to repair your plane.
Have you damaged your Pilot-RC airframe? Pilot-RC wants to get you back into the air with as little out of pocket as possible. The guys at Pilot-RC will send you the wood parts to Repair your airframe for the cost of shipping. That's right the wood is FREE. All you'll need to do after an accident is email detailed photos of your damaged Pilot-RC airframe along with your name and address to pilot-rc@139 They will determine which pieces are required to properly Repair your plane, quote the shipping, and let you know where to send the funds. You can also purchase pre-cut covering at their cost. This offer is ONLY good for the Pilot-RC brand airframes.
Wing Bag $100.00
$4254.50
