Go Back  RCU Forums > Marketplace
Reload this Page >
QJE PS50SWIII switching power supply
Old 06-01-2020, 08:46 PM
wojtek
My Feedback: (73)
wojtek's Avatar
Default QJE PS50SWIII switching power supply
USED , good working order. Sold as pictured .
Shipping $14 USA
The QJE PS50SWIII switching power supply provides 13.8 VDC at 48 Amps continuous, 50 Amps surge. A front panel switch selects fixed 13.8 VDC or adjustable 9 to 15 VDC. It features a front panel lighter plug for low current (10 Amp) accessories. Red and black terminals (50 Amp), and a quiet fan on are the rear panel. The analog panel meter can display voltage or current. There is a Noise Off-Set Control that can be adjusted to eliminate pulse noise from the power supply. It has short-circuit protection, over-current protection and over-temperature protection, plus a user replaceable fuse. Output voltage regulation is less than 2% variance. Input is 110 VAC 60 Hz. 7.75 x 3.4 x 11.1 inches 5.6 lbs. (195x85x280mm 2.5 kg).
wojtek is offline
