Diablo
MB, CANADA
In the 1990's I owned this plane and it was the only plane to have ever done a perfect flatspin. Engine at idle and no chance of recovery unless you had lots of power. It was amazing and for THAT reason alone I would buy it again. Ive never seen a plane since that did a real (engine at idle ) flatspin. I remember the entry procedure I figured out. Rudder and elevator only spin to the left. Engine at idle. After 2-3 turns feed in down elevator while holding the rudder full. The nose came up and it went tabletop flat. No aileron was ever used or needed. GL with your search
