Aviation Design Super Scorpion (Custom)
Custom Built Super Scorpion
I personally designed and fabricated Gear Doors and complete interior cabin with 3D printer. All parts printed from PETG with Carbon Fiber to increase strength and reduce weight. I have documented the entire build with photos and videos. All build photos are available upon request. Jet is 95% done. Just Turbine and exhaust tube need to be installed. Turbine ECU, Landing gear, and receiver Batteries included. Includes all fuel equipment necessary for installation. Batteries can be charged without removing. All control surfaces have emotec connectors for easy assembly/disassembly. I will provide all 3d designed digital files in case you decide to print additional parts in the future. CG has been set with Xicoy digital CG equipment. Currently set up for Jeti. All programming done. If using Jeti I will email you the Jeti files. I have invested more than 200 hours into this project. You will not find a cleaner build.
Custom Painted (Satin Clear)
Custom Gear Doors (Over-engineered for durability)
Custom Interior panels
Aviation Design Super Scorpion Kit $2,911.00
Behotec Electric Landing Gear $1,677.00
Clear Canopy $55.00
Kevlar Tank $211.00
Thrust Pipe $179.00
Revoc Wing Bag Set $241.00
(2) Savoc SB-2270SG HV Brushless Servos $200.00
(7) Savoc SB-2274SG HV Brushless Servos $665.00
PowerBox Mercury SRS W/ Gyro $409.00
PowerBox GPS II $107.00
(4) Micro Linear Actuators (Gear Doors & Speed Brake) $274.00
Intairco Airtrap Itrap 60 W/ Air Bubble sensor Telemetry $260.00
Behotec JB-220 "The Beast" $3,990.00
Total $ 11,179.00
Local Pick-up preferred but will ship if necessary. Buyer responsible for shipping.
No Trades
Martin Kosar
(858) 699-6617
Clear Canopy $55.00
Kevlar Tank $211.00
Thrust Pipe $179.00
Total $ 11,179.00
No Trades
Martin Kosar
(858) 699-6617
