Rovan bm5 1/5 rc model car gas engines 4wd big foot truck - rtr version
BM5 1:5 RC Model Car Gas Engines 4WD Big Foot Truck (Car + Gas Engines + Remote Controller )(Random Car Shell) - RTR Version
Features:
.The Only Synchronous Remote-controlled Four-wheeler Truck On The Market, The Car Shell Is Very Beautifully Designed, With A 29cc Single-cylinder Air-cooled Two-stroke Four-point Fixed Gasoline Engine And A 2.4G Remote Control.
.Excellent Quality: The Chassis And Drive Structure Are Made Of High-quality Metal Materials. The Bottom Plate Is Strengthened And The Torsional Characteristics Of The Frame Are Optimized. The Impact Resistance And Stability Are Better.
.The Car Shell And Other Parts Are Mainly Plastic, Which Reduces The Weight Of The Vehicle Body And Reduces The Loss. At The Same Time, It Has Good Wear Resistance And Toughness, And Is Durable.
.Usage: The Product Is A Complete Vehicle Without Assembly, And Players Need To Bring Their Own Gasoline And Motor Oil. Please Read The Instructions Carefully Before Using It, Simply Familiarize Yourself With The Car And Start The Road
.Tips: There Are 4 Kinds Of Car Shells, Which Are Shipped Randomly; The Use Of This Product Can Make You Feel The Fun Of Playing Oil Tankers. If You Have Any Questions, Please Consult The Owner
.For Age: 14 Years Old And Above
Configuration Parameters:
.Scale: 1: 5
.Engine Type: 29cc Single-cylinder Air-cooled Two-stroke Four-point Fixed Gasoline Engine
.Wheelbase: 410mm
.Wheelbase: 500mm
.4WD / Rear Axle Brake / Synchronous Belt Drive
.15KG Digital Metal Gear Throttle Servo
.45KG Metal Gear Steering Servo (plastic Version)
.BM Exhaust Pipe
.Front And Rear Aluminum Alloy Differential
.Big Foot Tire: 220 X 120mm
.6mm Metal Shock Absorption
.Battery: SC6V4500 MAh
.BER 2.4G LED Screen 3CH Remote Control
.CNC Integrated Large Base Plate
.Exquisite PC Shell
.Reinforced Front And Rear Suspension
.Clutch: 8000rpm
.CNC Metal Clutch Bracket Kit
.Comes With An Emergency Repair Kit
.Truck Oil Package: Shock Absorption Oil, Air Filter Oil
.New Matching Pot
Specifications:
.Color: As Shown
.Material: Plastic + Metal + Nylon
.Product Dimensions: 76 X 50 X 36cm
.Product Weight: 15000g
.Package Dimensions: 115 X 57.5 X 41cm
.Package Weight: 22000g
.Packing: Double Carton Individual Packing
Package Content:
.1Set X RC Model Car(Car + Gas Engines + Remote Controller )
Features:
.Scale: 1: 5
.Wheelbase: 410mm
.Wheelbase: 500mm
.BM Exhaust Pipe
.Exquisite PC Shell
.Clutch: 8000rpm
.New Matching Pot
Specifications:
.Color: As Shown
Package Content:
