Kingtech K45 G2
Description:
I have a Kingtech K-45 G2 for sale. This comes with all the standard accessories of ECU, fuel pump, GSU, filter, full cable set, mounting strap, FOD screen and manual. This engine is basically brand new as it has ever only been bench ran and has never seen the air. Hence the reason it only has 55 minutes on it. Unfortunately this engine doesn't suit my application that I had it planned for and have no other use for it. Price is 1800.00 Cdn or 1350.00 US. Any shipping involved will be paid by the buyer. I do live in Calgary, Alberta Canada, so could meet someone if the distance was reasonable and you lived in the region. Acceptable payment is cash or Paypal with buyer paying all transaction fees. Please PM me with serious replies. K-45G2 Specifications: Diameter: 76mm (2.99") Length: 195mm (7.68") Weight: 700g (1 lb. 8.6 oz. ) Max. RPM: 170000 Thrust: 4.5 kg @ 15° C ( 9.9 lb @ 15° c ) EGT: 700°C max Fuel consumption: 155 g / min ( 5.46 oz / min ) Fuel: Diesel, Jet A1, Kerosene Lubrication: 5% Maintenance cycle: 25 hr USD300 Recommended pump: MCT pump (no priming valve) All specifications taken from the 2016 Manual.Calgary, AB
1275 usd??
Offering 1275 USD
Calgary, AB[/QUOTE]
Offering 1275 USD
Description:
I have a Kingtech K-45 G2 for sale. This comes with all the standard accessories of ECU, fuel pump, GSU, filter, full cable set, mounting strap, FOD screen and manual. This engine is basically brand new as it has ever only been bench ran and has never seen the air. Hence the reason it only has 55 minutes on it. Unfortunately this engine doesn't suit my application that I had it planned for and have no other use for it. Price is 1800.00 Cdn or 1350.00 US. Any shipping involved will be paid by the buyer. I do live in Calgary, Alberta Canada, so could meet someone if the distance was reasonable and you lived in the region. Acceptable payment is cash or Paypal with buyer paying all transaction fees. Please PM me with serious replies. K-45G2 Specifications: Diameter: 76mm (2.99") Length: 195mm (7.68") Weight: 700g (1 lb. 8.6 oz. ) Max. RPM: 170000 Thrust: 4.5 kg @ 15° C ( 9.9 lb @ 15° c ) EGT: 700°C max Fuel consumption: 155 g / min ( 5.46 oz / min ) Fuel: Diesel, Jet A1, Kerosene Lubrication: 5% Maintenance cycle: 25 hr USD300 Recommended pump: MCT pump (no priming valve) All specifications taken from the 2016 Manual.Calgary, AB[/QUOTE]
1275 usd??
Offering 1275 USD
Calgary, AB
Offering 1275 USD
Description:
Sent you a pm.
1275 usd??
Offering 1275 USD
Calgary, AB
Offering 1275 USD
Description:
Sent you another PM.
