Super Scale Comp-ARF Mk IX Spitfire
My Feedback: (28)
SUPER SCALE COMP-ARF MARK IX SPITFIRE
All composite Spitfire, super detailed, in and out. Complete airframe is fiberglass composite with all panel lines and rivet details. All control surfaces are internal. Scale details include full cockpit with sliding canopy and side door access with crowbar. Resin exhaust stacks are hollowed for engine cooling. Elevator and rudder have simulated trim tab adjustments. Also has pinking tape applied to the surfaces. Full flaps extend the wing to underneath the fuselage as in the full scale. Side scale panel has access to the Fromeco power switches, choke lever, LED light for the ignition on/off switch, valve for filling retracts and air gauge. Model is equipped with a DA85 engine with a custom exhaust system. All servos are Hitec high torque. Model is painted with Klaskote finish with satin clear coat. Colors are matched exactly to the scale color chips. Retracts and wheels are from Sierra. Will not Ship.
Wingspan - 105 inches
Weight - approx. 34 lbs.
Price - $5,000.00
Price - $5,000.00
