Super Tigre S2000 Engine with Muffler
NEVER USED! Vintage. Super Tigre S2000/25 Engine with rare Muffler - 24.89 c.c. displacement. 30 mm Stroke. 32.50 mm. Max torque 240 Kgf. Mm at 7900 rpm. Suggested prop size is 20x6 18x8 break in; 18x8 18x6 16x8 normal use. Made in Italy. Never used. Fuel: requires much less rich than usual. Using fuel based on methanol and castor oil, the percentage of oil will be of 15% during the initial running. Adding 5-10% of nitro in fuel will improve both performance & idling. The use of 20% castor oil, as usual, is most prejudicial to the performance of the engine. Shipping is extra and will be the most economical way possible. Shipping in U.S. only. PayPal only. REASONABLE offers considered.
