Go Back  RCU Forums > Marketplace
Reload this Page >
Robbe 8639-Roxxy BL-Control 900 12S Battery New (Never Flown)
Old 01-30-2022, 09:33 PM
jimmydelta
jimmydelta's Avatar
Default Robbe 8639-Roxxy BL-Control 900 12S Battery New (Never Flown)
Robbe 8639-Roxxy BL-Control 900 Series Brushless Regulator 975-12 Opto 75A 4-12S (New)
Note:This was never used. I just installed the plug and programmed it for 6s But you can set up at your convenience. The manual is clear and simple.Original Price $165.00.The helicopter is NOT included is only to Show the ESC.
Handling and Shipping $9.95 Priority Mail
Contact: [email protected]
Please pay PayPal Fee..(If you do not pay the fees, we will refund the money.)Firm
Programming options:
o Model type: Air / Heli, Boot / Car
o Battery type: Lipo, NiCd / NiMh
o Direction of rotation normal / reverse
o Brake on / off
o Governor mode (helicopter) Additional settings can be made with the separately available V2 programmer (# M318642):
o Cut-off voltage
o Behavior in the event of undervoltage (Cut Off Type)
o Motor timing
o Start-up behavior
o Control behavior (governor mode only)
o Braking behavior (only air mode)
o Number of motor poles
o Gear reduction
o Display RPM max.
o RPM average display
o Write data
o Read data
o Secure data These controllers are equipped with the following protective functions:
o POR: start-up protection, prevents the motor from starting up unintentionally
o PCO: undervoltage shutdown. The motor is switched off in good time when the battery is empty, to reserve enough capacity for the controller.
o hec: high clock frequency (32kHz) for sensitive, magnet-friendly motor control.
o PLC: Super Programming System
o Cool Power FET: New generation of transistors
o RX filter: Switches the controller off if the transmitter signal is missing or invalid. o TP: Thermal overload protection with subsequent power reduction to 70%
jimmydelta is offline
