Hanger 9 B-25J Mitchell B25
My Feedback: (15)
Fully assembled but never flown Hanger 9 B-25J Mitchell complete with twin Electric Motors / ESC's
HiTec metal gear Servos, Robart Air Retracts with Robostruts. Will need final checks, balancing , batteries and receiver. Also comes with electronic sound system and two speakers.
All new components to the build:
PropDrive 42 size electric motors with RedBrick 70Amp ESC's
1- PowerHD servo for Steering.
2- HiTec HS645MG Servos for ailerons
2-HK 15328D Servos for Flaps.
1-Hextronic servo for gear valve
2-HiTec HS82MG Servos for Rudders.
You will need a transmitter, Receiver, two battery packs, and battery charger. Plus you need to go through the entire plane and also balance it prior to flight.
The plane requires two Lipo batteries 4S 4200MA each.
Does include the original assembly manual for the B-25.
It also includes all the Servos and all the extension leads as needed. In addition it has a sound system installed with two speakers. Regarding hanger rash, it has a few chips in the cowls paint, plus it is missing a gunner from the back of the plane. It has a one piece wing.
