Custom upgraded HET Super Sniper 90mm
Custom HOT Jetfan upgraded HET Super Sniper 90mm
This may be the finest HET Super Sniper 90 anywhere. It was built by EJF. A fine build but lacking the newest parts and technology of today. Many hours and money were spent on this jet to make it fly with the speed and agility it was designed for. All new Jetfan 90mm V3 with HET 700-68-1680kv paired with new Castle Edge 130a 8s ESC. All servos are Hitec HS-82's except for Power HD 20KG full size servo for elevator. We spent hours on changing the exposed servo in the thrust tube. The thrust tube is .2 mill vinyl with 85% FSA. There is no obstruction in the tube now and no wrinkles that was in it earlier. The elevator was taken off and reset with hinged and pinned joints. All servo arms are metal with metal pushrods. The elevator has carbon tube for push, pull usage. Wing joint has 2 4x1 inch aluminum plates epoxied over joint for no wing collapse. Has E-Flight retracts. All retract openings are aerodynamically assessed by air deflectors. Custom battery tray and strap made for 2, slim, light Power Hobby 5200 4s batteries in series. It has been flown once for test. Jet weighs 7.35 pounds wet This jet is very fast and flies on rails. Comes with 1 cycled batteries. Add RX and fly. Over $1,100 invested, not including all the time. If you have any questions, please feel free to ask. No shipping. Live in Lakeland Fl. Will drive 40, or so miles to meet. Thanks for looking, Chris.
