Bill Hempel 25% Pawnee
AZ
Price reduced. Everything is basically brand new, only one flight on it, all equipment bought new for this build. I built this plane about 2 years ago and just have been so busy with work/ renovating a new house and haven't had much time to fly.
DLE-60 twin with stock exhaust. Foam baffling on the intake along with aluminum louvres for exiting air. No huge cutouts in the cowl, this was about the biggest engine I could squeeze inside this thing.
Skywriter smoke pump with separate LiPo battery
Flacon CF prop and CF spinner
Tech Aero IBEC
Booma RC Smart Bus Extreme with display mounted behind the cockpit. You can look through the canopy and visually see your battery status
Spektrum AR 9020 Rx
Dual Spektrum LiFe flight packs
I believe all servos are Savox 1270TG's, minus the flaps which are Hitec HSB-9380TH. 8 servos total
Tow hook, driven by mini metal gear Savox servo
Cockpit dash put together from iFlyTailies
Lastly, added scale lighting throughout the plane. There are 5 or 6 different sequences you can trigger from your Tx. Lights are very bright, easily can see them during the day.
Really nice plane, PM or text 480-789-15o1, thanks.
Tech Aero IBEC
Spektrum AR 9020 Rx
