Phoenix Model is proud to present the 90 percent-pre-assembled Cessna 182 size .46-.5
My Feedback: (12)
Description:
Phoenix Model is proud to present the 90 percent-pre-assembled Cessna 182 size .46-.55. OS Max glow engine. This plane is finely crafted from balsa and plywood and not a foamy! Made with such as high quality material, this is one great flying model. The Cessna 182 comes finished with iron-on covering just as you see it here, and the fiberglass cowl and wheel pants are hand-painted to match. Wheels, fuel tank, engine mount, and all hardware are included. Functioning scale flaps make takeoffs and landings a breeze.. The Cessna 182 ARF is a part of PHOENIX MODEL's!.
ALL SERVOS ARE INSTALLED AND GLOW ENGINE but cowl has not been cut.
INCLUDED IN PRICE-ELECTRIC MOTOR MOUNTING!
Technical data
- Wingspan: 1667mm (65.6in)
- Length: 1295mm (51 in)
- Flying weight: 3300-3400 gr
- Wing area: 34.2 dm2
- Wing loading: 85g/dm2
- Wing type: Naca airfoils
- Gear type: Aluminum Hi-grade for main gear and spring wire for nose gear (included)
- Spinner size: Plastic 58mm (included)
- Radio: 6 channel minimum (not included)
- Servo: 7 standard servo: 2 aileron; 2 flap; 1 elevator; 1 rudder; 1 throttle (installed)
- Recommended receiver battery: 4.8-6V / 800-1200mAh NiMH (not included)
- Servo mount: 21mm x 42 mm
- Propeller: suit with your engine
- Engine: .46-.55 / 2-stroke or .52/4-stroke glow engine ( included and installed!)
- Motor: brushless outrunner 1000-1400 W, 480 KV (not included but motor mount is included!)
- Experience level: Intermediate
- Plane type: Scale Civilian
RECOMMENDED MOTOR AND BATTERY SET UP
- Motor: RIMFIRE OS Max .46-.55 (glow enginet included)
- Lipo cell: 6 cells / 4000 - 5500mAh (not included)
- Esc: 50-80A (not included)
Feature
- Designed for compatibility with both GP and EP flight
- Bolt-on two-piece wing for easy transport and setup at the field
