Lanier Staudacher S-300 RTF
![](/forum/images/badges/premium_member.png)
My Feedback: (-1)
Description:
Lanier Staudacher S-300 96" Wing Span Ready To Fly with Fuji 86cc Twin Gas Engine Swinging a 24 x 10 Pro Zinger prop Servos and Battery. No Radio. Excellent IMAC or 3D Plane. Plane is READY TO FLY, I WILL PULL MY RECEIVER AFTER INSPECTION. The plane is a floater, fly's excellent and is in good to very good shape. Asking $800.00 or best offer.- Overall Fuselage Length 83-1/2 "
- Wing Span: 96"
- Wing Area: 1624 sq. in.
- Dry Weight(no fuel, has a 24 ounce fuel tank): 22#
- Battery: 3600 mAh Nickel metal hydride
- CDI Automatic Ignition Timing
- Built from a kit, not an ARF
- Covered in UltraCote
- Expertly painted Fiberglass cowl and wheel pants
SERVOS
Torque rating @ 4.8V @6.0V
- Aileron 2 Hi-Tec 605BB 76.4 oz-in 94.4 oz-in
- Elevators 2 Futaba S9402 89.0 oz-in 111.0 oz-in
- Rudder 1 Futaba S9204 131.2 oz-in N/A
- Throttle 1 Futaba FPS-133 ? ?
Starter: Sullivan DynaTron SUPER HI-TORK, REQUIRES 24 VOLTS(I use quantity 2, 7 Ah batteries in series for 24 volts). BATTERIES NOT INCLUDED.
General Information about Kit:
Meets IMAC Requirements, CNC Routed Cut Lite Plywood Parts and Bulkheads, Full Symmetrical Airfoil, Balsa Sheathed Foam Core Wing with Spruce Spars and Aluminum Wing Tube, Complete Built-up Tail Assembly, Built-up Fuselage with CNC Routed Cut Plywood Sides, Built Up Sheathed Turtledeck, Vacuum Formed Canopy, Hefty Pre-formed Aluminum Landing Gear, Fiberglass Cowl and Wheel Pants
Asking $800.00 or best offer. Local pick-up. I will not ship the plane it is too big.
