DLE 20cc with Pitts Muffler
My Feedback: (927)
DLE 20 engine
Very good condition, Rcexl Ignition system.
Very hard to find Pitts Muffler,
Plus Original muffler
Motor mount
Everything in photo included.
$185.00
You pay the shipping,
Box 8"x4"x4" 3 lbs coming from 34450
Engine Specs:
Performance : 2.5HP/9000rpm
Idle Speed : 1750 rmp/min
Static Thrust: 6kg/100 meters Altitude
Static Thrust: 5.3kg/1800 meters Altitude
Recommended Propeller: 16 x8 ; 17×6 ;17x7: 17x8
Spark Plug Type: CM6
Displacement : 20cm3
Diameter × Stroke : 32mm×25mm
Compression Ratio : 10.5:1
Lubrication Ratio : 30:1
Weight of Main Engine : 670g
Weight of Exhaust : 60g
Weight of Ignition : 140g
Ignition voltage: 4.8V-6V
Motor mount
$185.00
Engine Specs:
