Search limitations???
I'm puzzled why I can't get any search results for the phrase "K&B" when I KNOW I've seen this many many times in the forums. I've searched with similar length strings (6.5) and gotten results.
My Feedback: (33)
Go to
and typy in K&B engine then select the [ ] Less Precise Match option and see what you get, its the same exact search I did yesertday.
Also the search results (when there was none) are in white lettering and can barely read them, I had to highlight with dragging pointer to see what it said. See if you have the same problem? might be just my computer'
and typy in K&B engine then select the [ ] Less Precise Match option and see what you get, its the same exact search I did yesertday. Also the search results (when there was none) are in white lettering and can barely read them, I had to highlight with dragging pointer to see what it said. See if you have the same problem? might be just my computer'
I'd like to search for members from a particular state. Right now it is limited to username. There needs to be an advanced search to enter specific criteria and I'm not sure if I found the right "search" but I tried searching for info in forum messages and it doesn't seem to pick up the words I'm looking for.
