Misplacement of ad
My Feedback: (9)
FL
I was trying to place an ad for a receiver and I guess I placed in crystals. I went to remove the ad in crystals and got a message stating my account would be suspended if I removed it and placed it somewhere else. What can I do?
My Feedback: (325)
Try editting add and go to catagoty and hit "remove" button. The red button catagory list will pop up again and select the correct one (reciever only?"
1. SELECT LISTING CATEGORIES
READ THIS CAREFULLY:
You can have your ad appear in up to 1 categories. Please pick the most specific category because your ad will automatically display in any parent categories of the ones you pick [More info].
If you want your ad to be featured (listed above the standard ads in the category you select and all parent categories), just select the category you want and check the "Featured" box. You may be featured in up to two categories (provided the categories are appropriate). IMPROPERLY CATEGORIZED ADS WILL BE MOVED.
Your first category is free!
Additional Categories: Enable.
Featured in a Category: Enable.
Category N/A Price Remove
Radio Equipment > Receiver Only Enable Featuring $0.00 Remove
This is what it looks like just like when you placed the add.
Banned
btw..the reason we do this is to prevent "bumping". some guys would delete their ads and then place another to get to the top which isn't fair to others. we have systems in place to monitor this activity.
the easy solution is what guver suggests here. just go to mymarket->selling and then edit your ad. go through each page and then when you hit the step 5 you can edit/change your category anytime.
also if somebody makes an honest mistake and deletes then relist it would be unlikely we would suspend anyone in isolated circumstances like this where the member was not aware of the proper way to fix their problem.
