Logging in
Logging in
Why can't I stay logged in while viewing this forum. Everytime I want to reply, I have to log back in, sometimes more than once. This is getting old.............
Banned
Logging in
Also, your cookies could be lost or corrupt which sounds like it also could be the problem...here is the fix:
Clear your cookies.
If using IE5 follow the below link:
http://www.rcuniverse.com/misc.php?a...1#clearcookies
If using IE6 go to Tools > Internet Options > Privacy Click Edit and enter to accept all cookies from your domain
If you are using the XP Personal Firewall, this can also cause this problem.
If you are using another browser follow whatever menus are necessary to delete the rcuniverse.com cookies or all cookies in the browser.
Your browser is likely reading an old cookie from before the upgrade. Once deleted a new one will be created and the problem should be solved.
Let me know if this works.
Clear your cookies.
Logging in
Thanks for all the advice, I'll check settings when I get back to work. I finally gave up and decided to what until I got home.
Thanks again, Ben
Thanks again, Ben
