Cannot get to MarketPlace getting Error
WA
Whenever I try and go to the market place I get this error.
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Session is invalid
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; .NET CLR 3.5.21022)
Remote Address 67.160.122.97
Referrer
Date/Time 20-Dec-07 07:57 PM
Session is invalid
Resources:
Referrer
Getting the same error, just started today. Occurs if I wait for while (sit idle) then try to access something. If I wipe out session cookies, I get back in.
Session is invalid
Resources:
* Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.11) Gecko/20071127 Firefox/2.0.0.11
Remote Address 999.999.999.999
Referrer
Date/Time 21-Dec-07 03:13 PM
Session is invalid
Resources:
Referrer
