MarketPlace questions or problem? Post questions or problems related to the RC Universe Marketplace in this forum.
Mark, Please help
Old 04-10-2003 | 03:08 PM
My Feedback: (12)
Default Mark, Please help
Something weird is going on that causes us to be unable to load objects and pictures. It occurs when I (we) access a thread in the 3-D Flying forum. Go to this thread and read posts # 96 - 99.
http://www.rcuniverse.com/showthread...60&forumid=230
Thanks, Robert..
Old 04-11-2003 | 02:38 PM
Banned
Just tested it here and all pics came up fine as well as full size images....try clearing your browser cache perhaps and restart your browser. Then go directly to that URL/page and see if it works if it is the first page you view.
Old 04-11-2003 | 07:40 PM
My Feedback: (12)
Default Still not working
Nope, it still is acting up. I have tried this from 4 different workstations, mine at home and 3 at work. Home is Windows ME, work is XP. Everything works fine until I try to access the page with post #88 on it. When I try to load that page, it loads through post #87, then everything after that hangs. The world Icon in the top right corner continues to spin. Then, anywhere I go on RCU I cannot load objects or images, the world keeps spinning. The smiley faces are gone, pictures and thumbnails won't load. Even the pictures under the RCU heading at the main page wil not load.
Right now all the symbols in the Message Icon field are blank. This happens even if I come in as a guest without logging on. I have to logout and clear my cache, then come back before anything works. If you read post # 96, 97, & 98 in the referenced thread, some others are having the same problem.
Old 04-12-2003 | 08:45 PM
Banned
some bizarre piece of code must be in one of the posts in that thread or one of the pictures has some bad header or something that is causing an anomoly...
Old 04-29-2003 | 02:06 AM
My Feedback: (12)
Default NOT GOOD
This really stinks. Several other people have tried to post to this thread and are getting the same results. This is really messing up a good thread. Is there anyway you can investigate to determine the cause and eliminate the source? Again, the thread seems to hang at post # 88.
Thanks, Robert.
Old 04-29-2003 | 03:48 AM
Banned
we can delete post #88 if that is ok with everyone or the poster himself?
Old 04-29-2003 | 04:03 AM
GrnBrt's Avatar
I thought that I would give it a try and see what happens, well the thumbnails were there except for post #88 and when I click on the other pictures they wouldn't come up either. I hit refresh and then all the thumbnails went POOF, like in gone!!!! Something is causing an error here for sure!
Old 04-29-2003 | 04:23 AM
My Feedback: (12)
Default Got it narrowed down
I went into my profile and changed the number of post per page to 5. Went through that thread a page at a time, but I skipped the page with post # 86 - 90. Everything worked perfectly. Then I went to the page with # 86 - 90. #86 and 87 loaded. #88, 89, & 90 did not load the thumbnails. Could not load the pictures. Then everything was messed up until I logged out, cleared my cache, then logged back in. The bad file(s) should be in one of those posts.
