RCU Forums
-   MarketPlace questions or problem? (https://www.rcuniverse.com/forum/marketplace-questions-problem-63/)
-   -   HTML code in classified descriptions (https://www.rcuniverse.com/forum/marketplace-questions-problem-63/10614267-html-code-classified-descriptions.html)
TripleDeucer 07-09-2011 11:55 PM
Can anyone tell me why all of a sudden I'm seeing all what appears to be code mixed in with the descriptions in the classified listings? I haven't changed any settings to my knowledge.
rcpete347 07-11-2011 08:59 AM
RE: HTML code in classified descriptions
HI, I am also having this problem today, please fix.
Rcpete
http://www.rcuniverse.com/market/item.cfm?itemId=763132
TripleDeucer 07-11-2011 09:35 AM
RC Pete, sorry your having the same problem, but then I'm happy to hear that it may not be on my end. Was afraid my puter started doing it's own thing. Hope they can figure this out as it's very distracting.
JWN 07-11-2011 10:11 AM
Our developers are looking into the problem. It only appears to happen when the Full Editor is used to create a ad description. If you select Basic Editor when building or editing your ad, the problem does not occur.
We will have this cleared up as quickly as possible.
TripleDeucer 07-11-2011 10:58 AM
I didn't change editors at any time when listing. I used the "Renew" button to renew some of my old ads. Maybe the "renew" button uses the other editor. Most ads I look at, other than my own, are all screwed up too.
After seeing this mess, I did change to the basic editor to see if the pages would look any different,which they didn't, and then changed back.
JWN 07-11-2011 11:03 AM
The Full Editor is the default selection. You do not have to change anything in order for this issue to occur in your ads.
If you change the editor to the Basic version, you can clean up your ad and avoid the problem until we can get the tools fixed. You must however manually remove all of the tags when you are in the Basic version in order for this to work.
scale only 4 me 07-16-2011 03:41 AM
I just edited my ad,, looks to be fixed,, thanks
