Go Back  RCU Forums > Marketplace
Engine Test Stand PSP >
Old 09-19-2019 | 02:45 PM
Default Engine Test Stand PSP
Height adjustable, 360 degrees rotating fuel tank mount.
ID:	2265242The best way to break in an aircraft motor/engine. RC Engine Test Stand, Engine Break in Stand. THE BEST PERIOD!!! Machined from 6061 aircraft aluminum with S.S. components. ANODIZED BLACK and GOLD. The PSPMFG Engine Test Stand, is the most versatile and safe stand on the market. PSPMFG Engine Test Stands will accept a very wide range of engines, from the small .10 size, to the Super-Tigre 4500, AND with the optional Back Mount Adaptor the GIGANTIC twin 150cc gas burner.Included is a deluxe cushion grip handled balldriver that fits all bolts, smooth operating throttle lever control with cable & throttle arm connector, and fastening hardware.The only engine stand designed with one wrench adjustments.Watch out for those cheap copies and imitations-INSIST on PSPMFG-THE BEST!
flyingmike is offline
Old 09-20-2019 | 05:31 AM
Default Optional back mount for big twins
Hi ,the U Shape bracket is for the fuel tank I presume? Do you have the other mount for the bigger engines? ,Thank you.
Jeff Denham is offline
Old 09-20-2019 | 05:49 AM
Hello Jeff I do not have the optional back plate for this
engine stand but should be available from the PSP mfg, and yes the U shape piece holds the fuel tank.
Michael
Old 09-20-2019 | 03:32 PM
My Feedback: (265)
Default Engine test stand
Hi I will take your engine test stand with everything included in your add is pappal ok ? That is if Jeff don't want it first. For your asking price of $60.00 thanks Carey.
Sea_Planes is offline
Old 09-21-2019 | 10:23 AM
My Feedback: (265)
Is the engine test stand still. available. ? Thanks Carey
Old 09-21-2019 | 10:52 AM
My Feedback: (169)
Hi Michael,money was sent via,paypal .
joedoan is offline
Old 08-13-2022 | 12:15 PM
My Feedback: (18)
Still available?
Rctofly is offline
