Jet munts 140 starting [roblems
My Feedback: (46)
I have a Jet munts 140 Which starts first start of the day and runs great, It will not start a second time, Fuel never ignites and I get smoke coming from the turbine.
I have used a fresh battery but has not helped. Can anyone give me a fix for this problem?
Thanks Steve
Thanks Steve
My Feedback: (21)
I had this same issue, I did two things, increased the voltage as like Rider-60 says, I also changed the battery to a battery with a higher C rating, which I believe is now 30C. As for increasing the voltage I did it 0.2 volts at a time until the problem went away. you can also reach out to Gaspar at Jet Munt he is very good in responding to emails.
Robert
Robert
My Feedback: (46)
Thanks for your reply. We did up the glow plug voltage and no problem starting. I also have a 4000 mah battery coming which should do the trick.
Again, Thanks for your reply. Steven Heyer
