Booster idea?
![](/forum/images/badges/premium_member.png)
AZ
Can I epoxy/JB Weld two or more Estes E12-0 boosters end to end, cap off the front booster, thereby having a longer run time? Planed use is in a scale model of a 50's fighter that used turbo jet and a rocket for power. I guess that the question really is can one booster fire through another case that has already fired.
Or buy a reloadable 29mm or 32mm RCRG motor and use longer burning reloads. While tandem staging works to a degree, are you willing to risk the time and money invested in the model for a pair of glued together black powder motors?
AZ
OK, so who/where is "RCRG" motor. I've never heard of them and haven't seen them in my local hobby shop. Please give me a web address so that I can investigate. Thanks!
RCRG = radio control rocket glider, and Aerotech makes 24mm and 32mm long burning reloadable composite propellant motors for them.
RMS-24 R/C Hobby Line Rocket Glider Reload Kit Data
Hardware Reload Total Impulse Prop. Wt. Loaded Wt. Delay Times
RMS-R/C 24/20-40 D7-RCT (3 pak) 20 N-sec 10.5 g 41 g plugged
RMS-R/C 24/20-40 E7-RCT (3 pak) 30 N-sec 17.1 g 46 g plugged
RMS-R/C 24/20-40 E6-RCT (3 pak) 40 N-sec 21.5 g 52 g plugged
RMS-R/C 24/20-40 E12-RCJ (3 pak) 36 N-sec 28.3 g 59 g plugged
RMS-32 R/C Hobby Line Rocket Glider Reload Kit Data
RMS-R/C 32/60-100 F13-RCT (2 pak) 60 N-sec 31.2 g 105 g plugged
RMS-R/C 32/60-100 F16-RCJ (2 pak) 80 N-sec 57.1 g 137 g plugged
RMS-R/C 32/60-100 F23-RCW-SK (2 pak) 70 N-sec 35.2 g 127 g plugged
RMS-R/C 32/60-100 G12-RCT (2 pak) 100 N-sec 51.1 g 126 g plugged
