989 question again
WI
989 question again
Could you explain to me a little about the auto cycle. It seems whenever I put a battery on the auto cycle it will only discharge for a short period and then either trickle or stop. Not sure what the deal with that is. I have tried a couple different packs and the same results. Am I correct on thinking the time that you can set up is for in between each stage of the cycle? Meaning if you set it for 5 minutes it will discharge completely then wait 5 minutes then start to recharge? Also with the amount of or cut off of volts you would want that low I would think correct? Thanks
NJ
RE: 989 question again
Sorry about that. Yes, all of you assumptions are correct. Although I would set the discharge rate for 1C to 3C. So if you're playing with that battery that you're not sure about, I would set the discharge rate for 1-3 amps.
Tim Sandor
Tim Sandor
