MRC SB 989 charge issue
Hi all, I have a 989 and I have encountered a problem charging a new transmitter battery. The NICAD battery is for a JR 10X, I had the local battery shop replace the existing cell with Sanyo cells (9.6 volts 1100 mAh). I have had success with 4.8 and 6 volt batteries but I am running into a problem with this set. I wanted to form the battery so my initial settings were .30 charge and .40 discharge.
I am connecting directly to the batteries thus bypassing the circuit board. The problem is I can discharge to 1120 mAh but can only charge about 890 to 900 mAh. I have tried 3 or 4 times adjusting the settings; this helped in the beginning but it has not improved.
Below are the last settings.
Common: NICAD, 8 cells, 1100 mAh
Discharge: .40 cutoff 1.10
Charge: .30, cutoff peak 10, trickle .10
Any ideas?
John M.
Any ideas?
John M.
NJ
RE: MRC SB 989 charge issue
Sorry John, I missed this one. Has anything changed with this? Are you still experiencing the same thing? Again, sorry I missed it, please let me know what you find.
That is correct, although I have not tried the 9.6 in about 2+ weeks, I am in the process of cycling 3 6.0 batteries. the first completed normally and the second appears to be functioning properly.
When the receiver battery is completed I will try the 9.6 again and verify the settings that I posted. Any Ideas?
John M.
John M.
Hi Tim, it was good talking with you at Toledo, putting a face with the e-mail. I took your advice and tried a couple of different settings. The temperature never got above 85 degrees and the room was at 67. Below are the results.
Test 1.
Chg. .70;Cut off peak 12; Dischg. .60; Cut off V 1.00
D1 935Mah D2 1006Mah
C1 998Mah C2 997Mah.
Test 2.
Chg. .40; Cut off peak 12; Dischg. .80; Cut off V 1.00
D1 917Mah D2 976Mah
C1 923Mah C2 919Mah
Test 3.
Chg. .30; Cut off peak 10; Dischg .30 Cut off V 1.00
D1 1109Mah D2 1230Mah
C1 881Mah C2 846Mah.
I think I will go with test 3 since it gave me the best discharge. Admittedly, I cannot figure out why I can take out 1100 mAh and only charge 850 mAh+ As you said the transmitter does not have a high draw so this should be fine.
An interesting problem maybe someone will come up wit a plausible answer.
John M.
Test 1.
Test 2.
D1 917Mah D2 976Mah
C1 923Mah C2 919Mah
Test 3.
John M.
