Having 960 charging problems?
MD
I'm getting false peaks on all my packs. Charging EnerG 4600 seven cell and 4200 six cell packs. The seven cell pack are set to 35mV but it will only take a half charge before it shuts off. The six cell is set at 30mV and does the same thing. I have increased the milli volts setting by 5 but it still only charging half way. If I want to get a complete charge then I have to start it over again and watch the temps. Any help would be great. Thanks.
NJ
Are these brand new packs? If so, it is very typical for new packs to false peak the first couple of charges. Also, what charge rate are you charging these packs at?
Tim
Tim
MD
No these packs have at least 25 cycles on the them some even more. I have tried a charge rate of one and up to three. This charger worked fine before, I have had this one for a couple of months now. It just started to act up the last couple of charges. I tested to see if I had a dead cell in the first pack it happen to but it has done it to all of them and I have a total of four packs. Thanks.
NJ
These are run packs for your car/truck? If so, I would try charging them at 4.5 amps or higher and see what happens. You should be fine charging them at the higher rate.
Tim
Tim
MD
I will try the higher amps and up the mV. I do have a temp gun so I can check cell temp to make sure I don't cook the cells. Will let you know what happens. Thanks Tim for the help.
MD
Hey Tim? Charged my EnerG 4600 seven cell side by side pack with setting 4amps and 40 mV. The charger false peaked, it finished with 9.78V it only charged for 21.4min and only put 1430m back into the battery. Something is not right!
Banned
Hello Sir,
We are OEM factory specialize in Rc digital balance charger about 8 years,
The high capacity and power of charger shall provide your rc more energy when you play flying,
The typical features of our intelligent balance charger is Time limit funtion, input voltage monitoring, data storage, individual cell balancing, temperature sensor,
The details can be browse our website www.ev-peak.com.
Wish it can interest of you. Any other question please contact me feel freely.
<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">
Best Regards
Wennie He</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Shenzhen Ev-Peak Electronic Technology Co,.Ltd</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Tel:86 755 2917 7881 </font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Mobile No: 86 150 1850 8672</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Fax: 86 755 2917 7880
</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Email: [email protected]
Msn:: </font><font face="Trebuchet MS">[email protected]</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Skype: angelyoho</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt"><span lang="EN-US"><font face="Trebuchet MS">Website:www.ev-peak.com, </font><font face="Trebuchet MS">www.evpeak.en.alibaba.com/</font></span></p>
Best Regards
