HELP!!! FRAME/CHASSIS FOR MULTICOPTER
Hello All,
Can anyone help me in identifying the best frame/ chassis for a multicopter. Please also give me details of different types of frames with their advantages and dis-advantages. Please help me in starting my new project... Which one is the strongest regarding material ?<br type="_moz" />
It all depends on what size copter you want and what your needs will be. I build my own frames from scratch using aluminum and a material called Phenolic( its like a wood based carbon fiber).
ORIGINAL: geekofcomp
Hello All,
Can anyone help me in identifying the best frame/ chassis for a multicopter. Please also give me details of different types of frames with their advantages and dis-advantages. Please help me in starting my new project... Which one is the strongest regarding material ? <br type=''_moz'' />
Hello All,
Droidworx
www.droidworkx.com.au
Now there is another competitor in the professionnal domain for multirotor fram : me
you can find my products on this website: www.1001copters.com
I have designed heavy lift frames (X8 and hexa) for the professionnals.
ORIGINAL: 1001copters
Hi, Irish,
I'm sorry but no my X8 version isn't under $200.
There is only one 600mm diameter foldable frame in the world made with aeronotic quality aluminium
If you make a small research you will see that my prices are very reasonnable respect to the quality of the frame I sell
Hi, Irish,
Hi, Irish,
you should produce an entry level cheaper frame for beginners tho you would have some success
Yes, I think so but develloping these frames took me 3 months, develloping another frame would take a loooong time.
I need to produce an Y6 frame too, a professionnal camera mount, a retractable landing gear etc...
I started my activiti in frame building by propsing a bulk order for an SLE X9.01 frame, the operation was a non profit offer and the cost of one single frame was 95€ (without nuts and bolts...), the frame was smaller and not foldable. I let you imagine the production cost of an HEXASTAR now
the old bulk order can be seen here :
SLE X9.01 frame produced and anodised
the diameter of the SLE was 480mm.
(and before any asking: it's no more available
)yea i already knew about that thread and the frame i found it to late lol unfortunatly i only fly quad types and im looking for a Q4 hammer i do have the cnc files for it, i also have a cnc router 12x24 just havnt used it yet.
hmmm well ... you know the Q4 hammer isn't an open source frame ^^
You should use the SLE X9.01 drawings: the frame is better than the Q4: more stifness.
can you send me the dxf cnc files? in an email etc then i will cut it on my own machine
