MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Radial Mount on 2.15
Old 04-25-2005 | 02:27 AM
BAS
My Feedback: (28)
Default Radial Mount on 2.15
What is the distance in inches of the MVVS 2.15 using the radial mount from the firewall to the spinner backplate trying to figure out distance for mounting on a Texas Hurricane / cowl mounting. Also do you feel this motor will fly the plane adequate for pattern flying, no 3d . It weighs around 14 lbs and has a 78 " wingspan. It is basically a edge 540 design aerobatic type design. I have flown this plane with a Brison 2.4 using 20/8 menz standard prop turning 7400 rpms. and have also used a Brison 3.2 swinging a 22/8 menz prop. It actually flys better with the smaller 2.4 gasser and 20/8 prop. I will using a Bissen pitts style muffler for this motor.
Old 04-25-2005 | 02:12 PM
Default RE: Radial Mount on 2.15
140mm
Old 05-05-2005 | 02:22 AM
Correction:
I just received the parts. It should be 151mm from back of radial mount to front of prop drive washer.
The partnumber includes 4 M4x15 screws, the required allen key and instructions.
The 2.15 will fly your plane very well, turning an 18x10 Mejzlik at about 8000 rpm and 20x8 around 7300 rpm
Old 05-05-2005 | 04:25 AM
BAS
My Feedback: (28)
Ok thanks for the info i allready have the mount coming from David Moen but thanks for the update. I think it will fly the Hurricane very well.
