MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVVS 26 throttle and choke set up.
Old 10-26-2005 | 06:22 AM
Default MVVVS 26 throttle and choke set up.
Hello,has anyone any photos of their throttle and choke servo and pushrod setup?
I will be getting the bisson inverted wraparound pitts for this engine, and although I dont have the exhaust as yet, I'm thinking there may be a problem routing these lines through.
It appears the exhaust would block all attempts.
Maybe I'm wrong, as I said, I dont have the exhaust as yet, but just in case....
Many thanks.
Old 10-26-2005 | 09:17 AM
DarZeelon's Avatar
Default RE: MVVVS 26 throttle and choke set up.
Euclid,
The last time I looked, the MVVS 26 cc engine did not have a choke...
The Walbro throttle uses a ball-joint and routing is quite straightforward; similar to any normal R/C carburettor.
Maybe if you take a photo and post it here, we can see what problem you are encountering.
Old 10-27-2005 | 04:06 PM
My MVVS26cc gasser has a choke on it...
