MVVS 2.15 muffler, add a second pipe...
Hello everyone and thank you all for your time,
I have a 35cc MVVS engine, the old type with the standard black square muffler, and I remember reading someplace that if I was to bore a second pipe beside the first one on the muffler, I would get much better performance and response.
I just wanted to ask you gentlman if this is true and the easiest way to go about doing this. is it really worth the effort? and will I notice the improvments?
Thanking you in advance.
Mohammad Reza.
Mohammad Reza.
The muffler, whilst fine for scale applications, is extremely small and will respond to anything that increases or decreases the outflow of gasses. Sealing the seams will reduce power. Adding an extra stinger pipe will increase power, at the cost of added noise levels.
It is not the purpose of this question (I hope) to provice a course in soldering or brazing ??
If serious power is needed, get rid of the muffler, and fit either a MVVS 3271 or a MVVS tuned pipe, or canisters as provided by several dedicated suppliers.
Thank you very much Pe,
You are always the first to the rescue.
I will do as you say and place an order for the 3271 muffler.
Mohammad Reza.
Mohammad Reza.
