MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS / Evolution Quiet exhaust system
Old 01-16-2006 | 01:55 PM
kevinbell's Avatar
Default MVVS / Evolution Quiet exhaust system
I don't have any experience with these petrol engines but our flying site might be slightly noise sensitive. For both the MVVS 45cc and the MVVS 58cc, what would be the quietest exhaust system for it? I was thinking of the wrap around system I would like it to be light as well.
Old 01-16-2006 | 02:04 PM
Default RE: MVVS Quiet exhaust system
If your field is noise sensitive, you would need to consider a number of things that generate noise:
1) Exhaust system: The MVVS 3204 is the lowest noise system As far as I know
2) propeller: Use 3 bladed props, and keep rpm low (below 6500) Some props are noisier than others, so it pays to ask around
3) airframe resonance. this often generates more noise than you may be aware of. It can be influences by prop balance, engine mounting etc etc.
When you approach 80 dB(a) at 7 meters, the above factors are equally important.
