MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
which needle is which on mvvs26?
Old 04-27-2006 | 12:26 AM
Default which needle is which on mvvs26?
Hi guys, wondering if you can help me.
My carb has both needles vertically orientated above each other, and I have no idea which is the high end and the low end.
cheers.
Old 04-27-2006 | 01:22 AM
DarZeelon's Avatar
Default RE: which needle is which on mvvs26?
Mike,
On the body of your Walbro carburettor, next to each needle, there is a letter.
'H' signifies 'high'.
'L' signifies 'low'.
The upper needle is the 'high' and the lower needle (nearer to the base of the carburettor) is the 'low'.
Old 04-27-2006 | 01:41 AM
If that were so Dar, I wouldnt need to know which one was which!
But thanks for the info Dar.
Mike.
Old 04-27-2006 | 02:47 AM
DarZeelon's Avatar
Look at this drawing:
Log into http://www.mvvs.nl
Go to 'Petrol' on the left and scroll down to the carburettor adjustment instructions hyperlink.
Click and look.
Old 04-27-2006 | 12:16 PM
PS,
That is the very sparse MVVS leaflet. Better visit my forum, where I explain the carb in detail using the original Walbro documentation.
The needle closest to the engine is the idle, the upstream needle is the high speed.
Check out [link=http://www.prme.nl/forum/viewforum.php?f=7&sid=f61cb2f37e804647cabffbf784cf d486]http://www.prme.nl/forum/viewforum.php?f=7&sid=f61cb2f37e804647cabffbf784cf d486[/link]
Old 04-27-2006 | 09:44 PM
thanks Pe. I had found that thread and read it thoroughly. The needle identification eluded me throughout though!
Thanks for clearing that up guys.
Old 04-28-2006 | 06:32 AM
I updated the forum publication. Oftentimes you tend to forget how difficult all beginnings were.
