MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
What's voltage for the new MVVS's ignition ?
Old 07-01-2006 | 06:17 PM
Default What's voltage for the new MVVS's ignition ?
Hi,
I have buy the last mvvs 45cc and i have put a 1s2P lippo on agnition. But the led of ignition is flickering for to inform that battery is empty and there is no spark ! I checked and it's not empty ! I don't understand this ignition. What's is the good voltage 6volts ? 7.4volts ? or 8.4volts ?
And, I did not understand the programming of the system easy start !!
Please help me.
Thanks.
Pascal.
Old 07-02-2006 | 04:33 PM
Default RE: What's voltage for the new MVVS's ignition ?
You need a 2S pack
Old 07-03-2006 | 05:35 AM
Hi,
I have a 2s put on ignition and the Led is flickering ! But my lippo is full ! Are you sure that 7,4volts is enough ?
Pascal
Old 07-03-2006 | 02:39 PM
Ramz's Avatar
What does the instruction manual say for battery voltage on the ignition?
Old 07-03-2006 | 02:56 PM
Manual say 2s ! And for voltage : 6 - 8.4v
2s is 7.4v but maybe it's no enough ?
Old 07-04-2006 | 12:58 PM
even and fast on-off blinking is low voltage
long on-short off blinking is long silencer ignition curve
long on long off blinking is short silencer ignition curve.
If you have a ICU professional, it needs 9-13 volts
Old 07-04-2006 | 03:57 PM
Hi,
Thanks but my question was "2s (7.4v) is enough ?"
Tomorrow I buy a 8.4 nimh pack for to try. And when you don't know something you can say "I don't know" preivers !!!
Old 07-04-2006 | 04:27 PM
Tor's Avatar
Tor
ORIGINAL: flassh
Hi,
flassh - Pe did answer your question "You need a 2S pack"
You wrote you had a 2P pack, that is only 3.6 volts.
Maybe that is your problem.
Old 07-04-2006 | 05:00 PM
Old 07-04-2006 | 05:01 PM
2S1P (2s) is 7.4v. So is it enough. If you have the mvvs 45cc with the new ignition you can talk about battery that you use.
Old 07-04-2006 | 05:05 PM
I'am writting a new message to explain what I want. So wait 3 minutes, please.
Old 07-04-2006 | 05:12 PM
Which voltage use to be made function this new ignition ? Me with a 2S1P it answers me that the accumulator is discharged. Thus does that want to say that it is necessary to use an accumulator of 8,4v? And to finish that what 6 - 8.4v wants to say? It is the beach of use?
Old 07-04-2006 | 05:16 PM
Tor's Avatar
Tor
ORIGINAL: flassh
Hi,
Pascal, 2S is not the same at 1S2P. You need a 2S1P pack to be precise.
7.4 volts (2S1P) = ok (7.4 volt is between 6 and 8.4 volts)
3.6 volts (1S2P) = not ok (3.6 volts is not between 6 and 8.4 volts)
Old 07-04-2006 | 05:21 PM
Tor's Avatar
Tor
ORIGINAL: flassh
Yes. It will accept anything between 6 (minimum) and 8.4 (maximum) volts.
Best is LiPO 2S1P at 7.4 volts because it is lightest.
Or you can use 6 cell NiMH/NiCD at 8.4 volt (but is alot heavier)
5 cell at NiMH/NiCD is not a good option, as you will get low voltage warning as soon as the battery goes below 6 volts.
Old 07-04-2006 | 05:26 PM
Yes I have a 2S1P (7.4v).
I know that 2S1P is 2 elements of 3.6v and I reapeat I HAVE 2S1P PUT ON IGNITION AND IGNITION SAY THAT IT'S EMPTY !!!!
I looked at behind the ignition and I have see a big "P" maybe my ignition is a professional version ?! It's crazy ! Usually the 45cc is delivered with a standard version of ignition ?
Old 07-05-2006 | 12:48 AM
cyprusjets's Avatar
Flassh
Check your ignition with these pictures and see if your ignition is the same as this one. If its the [P] then you need to use more voltage 9-12volts. The 45cc are coming with the standard version ICU, so maybe its a mistake and you got the Professional, this may not be very good though because the P is working on the prosport ,LC and 116cc. with more advance curves and they are using different flywheel to support this ignition. so what i suggest to you if you have the P which should have the voltage written at the back of the ignition as well, use the right amount of volts for example 9-12 volts and try to run your engine to see if the ignition is working correct with your flywheel.
Regards
Eftychios
Old 07-05-2006 | 12:50 AM
cyprusjets's Avatar
pictures
ID:	487286   Click image for larger version
ID:	487287   Click image for larger version
ID:	487288   Click image for larger version
Old 07-05-2006 | 04:18 AM
Thanks cyprusjets. Yes I have the P version ! I have put a 3S1P on ignition and I have a BIG spark ! I will try to start the engine on saturday with friends at field.
Old 07-05-2006 | 04:25 AM
cyprusjets's Avatar
I am glad your problem is solved and i hope the P ignition will not cause any problems with the 45cc flywheel.
Hope the best for you, enjoy your flights!!!
Regards
Eftychios
Old 07-05-2006 | 05:02 AM
The summer will pass very quickly and I would undoubtedly not have time to finish my Extra-330L before leaving on holiday. I lost more than one week to be tried to make function this (b)uk ignition!
Old 07-07-2006 | 02:18 PM
Hi !
Today the engine have run very well. I have mount a 22x12 propeller and the engine is very impressive. The choke is controlled by ignition. The idle is gone down to 887 rpm !!!!!!!!! Enjoy this engine !!!!
Old 07-07-2006 | 05:27 PM
cyprusjets's Avatar
I quess someone is happy here!! I am glad to hear that flassh, so i can take it that it was worthed the one week of delay you had to get the things to work.Enjoy!!
