MVVS 26ccm gas engine.
I am a newbie to gas engines, and I have just bought a new MVVS 26ccm for a Giles 202 140 model I am about to set up.
The engine is equipped with the standard 3270 muffler. There is not much room between the muffler and the choke lever, and the lever does not seem very logic in its shape and position for connecting a rod from a servo.
Could anyone advice some practical way to connect a servo rod to the choke?
Best regards,
Helge.
Best regards,
Helge.
If you want to use a servo, unhook the choke plate spring and use whatever linkage is needed to get the job done.
Most users prefer a simple manual pull rod or pull cable, in which case you leave the spring installed.
