MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
mvvs tuned pipe
Old 11-04-2006 | 12:12 PM
Default mvvs tuned pipe
Hi, can someone please answer a question? I recently purchased a complete evolution 26gt tuned pipe thinking it would fit my mvvs 1.6 gasser but the bolts on the header do not match to the engine is there an adapter plate or is this the wrong header(2.15?), the bolt holes are further apart one the header then the engine,if this is th eworng kit how can i tell? The pipe is 27" long and the header is 7.5" long from the center of the intake end.
Thanks Brad.
Old 11-04-2006 | 12:23 PM
DarZeelon's Avatar
Default RE: mvvs tuned pipe
Brad,
The MVVS (and the Evo) 26 cc engine have the exhaust flange bolts 36.5 mm apart (center to center).
The MVVS (and the Evo) 35 cc engine have the exhaust flange bolts 40.5 mm apart (center to center).
Check to see what you received.
Old 11-04-2006 | 12:34 PM
Thanks Dar,
Yes it is 40.5,what about the pipe? What is it supposed to be?This one is 685 mils long.
Old 11-05-2006 | 10:59 AM
Look at http://www.mvvs.cz/e11.htm for all dimensions and http://www.mvvs.cz/d21.htm for other information .
