MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Evolution 35-GT question
Old 04-20-2007 | 09:39 PM
Mr67Stang's Avatar
Default Evolution 35-GT question
EDIT// Never mind. After I got over my frustration and went back out to pop off the cowl and start pulling the ignition I found the problem... ignition probe wires melted to the exhaust.
What does the red LED light mean? When I turn on my ignition it flashes once... then I flip and it normally starts soon after. Then today I cant get it to run. I noticed the LED was on constantly so I changed batteries 600 mah 4.8v NiCad (old ignition style). My light went back to one blip at power on but it will not start now. I have only had the engine for a short time but got it used and I think the previous owner was using a 7.4v LiPo on it as that is what he sent me with the engine... Will that burn out this ignition module? Or should I be using the higher voltage even on the older 4.8v ignition?
Old 04-21-2007 | 05:49 AM
Default RE: Evolution 35-GT question
If it has the Vlach blue wrap EZM ignition, 2xLiPo was way too much voltage and it may be gone.
If it is the MSR potted ignition, a 4-cell pack is way too little voltage. This ignition needs the 2S Lipo or equivalent voltage pack. The ignition cuts out at 6.4 Volts
