ICU-L Led code
Hi,
What does it mean if the LED on the ICU-L ignition stays lit after switching on? The manual shows only two codes, (Ok, or battery dead)
but not what it means if the LED stays lit.
Thanks!
Sny.
Thanks!
Sny.
My manual shows three codes:
Fast blinking after power up = battery test running
Fast blinking (5 seconds after power up = battery voltage low
One short flash persecond= sleep mode.
I have the original instruction sheet and the new one available on Pe's web site and neither mention the LED on permanatly state. Sorry not to be any help on this.
Mike
EDIT: just thought of one other place I can check, hold on.
Mike
Nope sorry, I thought I would check the Evolution manual just in case, but it does not mention this state either, I am sure that Pe or someone will come back with a reason after the week-end.
Good Luck
Mike
Good Luck
Mike
MSR Engines or whatever does not know what it means either. They are sending a replacement ignition.
Nobody else has ever experienced this?
I was thinking of buying the 45cc, but now I am a bit worried.
Don't be concerned about the 45 its the most powerful 43cc engine out there, on par with the DA50 IMO the 58 Pro is even better, my 45 is in a 2M Extra and the 58 is in a QQ 85" Yak, can't fault them, the only problems I have had have been of my own making.
Mike
Mike
C onnect LED indicator to the ignition box (red/black wire to “+”).
U sing the included connector, plug your battery pack into the ignition box.
F ive seconds after connecting the bat¬tery, the LED indicator should go out. If the LED is blinking after you connect the battery, the battery’s voltage is too low.LED
