mvvs 58 needle mixup
The forum support guys are not gettin notifications of new posts, I suggest you PM Pe Reivers, as I have mine set up and running well I am loath to remove the neddles, the only help I can give is that with both installed they project the same amount, I don't know if that helps, but I wish you well.
Mike
Mike
The needles cannot be interchanged because the thread on each of them is of different phisical size.
Walbro monkey-proofed it a long time ago.
@ mike:
I shipped your back mounts today! Have about 4 hours mail backlog, and no time to do all I want.
@ mike:
Thanks Pe, I had got your e-mail, I will be installing these in a Composite ARF 2.1 Extra, look out for the build thread when I eventually get the plane.
Mike
Mike
58cc can you tell me whitch needle goes in the h side the longer one it seems i got them mixed up can you help
