MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
35CC How much shaft runout is normal?
Old 12-22-2007 | 03:14 PM
Default 35CC How much shaft runout is normal?
My very good running 35CC recently had prop/spinner contact with terra firma. The dial indicator shows some runout at the end of the prop shaft. Can anyone tell me how much is normal?
Thank you and Christmas greetings to all,
Sam
Old 12-22-2007 | 03:23 PM
DarZeelon's Avatar
Default RE: 35CC How much shaft runout is normal?
Sam,
The specs say 0 run-out...
...But if you can get it straightened to within 0.1mm (.004" ) run-out, the vibration level would be unnoticeable.
Old 12-22-2007 | 04:23 PM
Thank you Dar,
Exactly the information I was looking for. Excellent engine.
Sam
