MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Evo 58GX2 oil
Old 07-07-2008 | 09:56 AM
duber3's Avatar
Default Evo 58GX2 oil
Hi!!
I know that you recommand to use Mobil oil synthetic
but in my area I can't find it, is the Motul semi-synthetic is a good
choice??
thank!!
Old 07-07-2008 | 04:06 PM
Default RE: Evo 58GX2 oil
use motul 800 at:
Motul 800 RR racing synth 3-4%
Motul 800 OR offroad synth 2%
Old 07-20-2008 | 06:17 AM
duber3's Avatar
Hi Pe!!
I fanally found the motul oil, I bought the offroad
You said with Motul 800 OR offroad synth 2%
on the bottle 2% = 50:1, evolution recommand 40:1
Do I'll go with 50 or 40:1
thank!
Old 07-20-2008 | 01:57 PM
for the 58cc, use 3% for the first tankfuls, then taper down to 2% as the engine runs in.
Old 07-21-2008 | 02:28 PM
duber3's Avatar
thank!!
Old 08-26-2008 | 06:43 PM
duber3's Avatar
Hi Pe!
I flew my plane a lot last week, with the motul rr at 40:1
I noticed that under the fuse there is a lot of black risidue
Is it the oil that making this or because the motor is too rich
Evolution recommend to put HS at 1 3/4 mine is just a little bit richer like "1 13/16"
the motor is running great with this setting
thank!!
Old 08-27-2008 | 08:15 AM
That is what gas engines do when new.
As the engine runs in, the black will get a lighter shade, and finally goes away nearly completely.
Old 08-27-2008 | 10:03 AM
duber3's Avatar
Thank!!
