MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 58 Prosport
Old 11-09-2008, 01:09 PM
tonealone
My Feedback: (28)
Default MVVS 58 Prosport
How can you identify an MVVS 58 prosport vs regular version.
thanks
Old 11-09-2008, 05:35 PM
pe reivers
Default RE: MVVS 58 Prosport
Look here, http://www.mvvs.nl/MVVS/main_bestanden/petrol.htm
On the ouside, little is different.
Old 11-11-2008, 11:34 AM
tonealone
My Feedback: (28)
Thanks for the reply,
Is the only visual difference the small label.
Old 11-11-2008, 12:20 PM
pe reivers
there is no small label
the engine has the carb trumpet and titanium prop bolt as visual differences. The ignition is the 10V type (3S-LiPo)
Old 11-11-2008, 02:02 PM
tonealone
My Feedback: (28)
There appears to be a small engraving on the drive washer (part 1101).
Mine has the vlach ignition so i presume its a regular version.
Old 11-11-2008, 07:12 PM
pe reivers
Indeed there is the engraving.
Older prosports also had the Vlach ignition. Tha standard engine has a plain washer without engraving.
Old 11-15-2008, 01:25 PM
tonealone
My Feedback: (28)
Do you know if it is OK to use an unregulated lithium battery at 7+ volts to power the Vlach ignition or will it cause damage?
Old 11-15-2008, 05:35 PM
pe reivers
Vlach will only run with 4 nicad or 4 NiMh. Anything more will put the ignition at risk.
Old 01-22-2009, 10:45 AM
Kema
When prosport is back in stock? The new 50 is also interesting but I really want to see the price
Old 05-18-2010, 01:07 PM
Felix72
Felix72's Avatar
Hi,
I have got a second hand MVVS-58 and I am trying to guess if its a Regular one or a ProSport.
I don't really understand what you guys mean for engraving, I observed my drive washer but I can't tell.
It has the VLACH ignition coded EZM 1 TI on its blue box and also with a number: 241834.
Do this tell something to some of you?
Here is the picture of my engine's drive washer:
Other then this I don't really know how to identify what's the engine I have!!!
Old 05-18-2010, 01:57 PM
pe reivers
The prop drive of the prosport has "prosport"  engraved on it. If not, you have the standard engine. In addition, the prosport has a titanium prop shaft. If yours is zinc plated, it is a standard engine. Other changes are inside the engine, like reworked piston and expensive bearings.
Old 05-18-2010, 03:53 PM
Felix72
Felix72's Avatar
Ohhhh,
so looks like the one I have is a regular one, ok, that's nice to know...at least I can be sure of what I have.
Thank you very very much for helping me to find out, you have been of great help.
Gianluca
Old 01-12-2011, 10:52 PM
Kema
I received engine back from factory and both bearings were changed in warranty. Engine was testes and now I can put it back for next summer to come.
Great service[sm=thumbup.gif]
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
