MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS Carburetor
Old 03-30-2009 | 06:14 AM
ggroyal1's Avatar
Default MVVS Carburetor
Can the plastic fuel inlet nipple be replaced? The older ones have brass nipples. I would like to replaced the right-angle plastic one with a straight brass one. The new design makes it harder to install the throttle linkage.
George G. Royal
Old 03-30-2009 | 07:37 AM
Default RE: MVVS Carburetor
If I had to do it, I would saw off the plastic part, and press in a brass tube.
The plastic part will probably break if you try to twist it out
Old 03-30-2009 | 08:43 AM
ggroyal1's Avatar
Thanks Pe, you saved me a lot of grief, I almost broke it off.
George G. Royal
