Evolution 26GX - choke operation
ON, CANADA
I will be mounting an Evo 26GX inverted in a cowled Sig Rascal 110. Should the choke be operated by a servo ? If yes, linkage suggestions would be appreciated.
leave the choke in place, especially in an inverted application.
Linkage? choke lever and straight through sullivan cable with ball links should do it. You may have to make a lever though. If that is too difficult, find a mechanic to help you fly your planes.
ON, CANADA
Thanks for responding. I'm not sure what you mean by leaving the choke in place. Do you mean leaving the choke closed ? ............George
