MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Self made problem with ignition MVVS26
Old 09-30-2009 | 06:02 PM
Default Self made problem with ignition MVVS26
I managed to rip out the cable from ignition box to the sensor on the engine. Can someone pls help me with where to solder which cable?
Thx
Ola
Old 10-01-2009 | 09:59 AM
Default RE: Self made problem with ignition MVVS26
Sorry, Can't help you. The unit I have available is potted.
I'll ask MVVS if they can respond.
Old 10-02-2009 | 06:15 AM
Here is the reply from MVVS, with thanks to Lukás:
<span lang="EN">I have not picture. But I will try explain it.
Look at the ignition from s/n number side. Side where is hole for sensor cable.
The connector for led diode etc. goes to the left.
The three cables from sensor are soldered between two "mainboard" in following order brown (TOP), white (MIDDLE), green (BOTTOM).
SORRY for my English.
Best regards
Lukas Chymek
Technical Support / Technick&aacute; podpora
MVVS
"</span>
Old 10-02-2009 | 02:54 PM
Super!
It's really good to know its possible to get such after sale support on MVVS products.
Gonna burn my fingers right away and see if I can get it running again.
Thx a lot!
Ola
