MVVS.91 Break-in Prop/Final Prop
I have just purchased an MVVS .91 :)I plan on following the break-in procedure as outlined by Dar Zeelon in the post Breaking in the MVVS .49 unless there is something I should do different with the .91. I am requesting information on the size and pitch of prop I should use for the break-in period and also what prop to use on my plane. My plane is a 66" Vector Flight Edge 540 should weight 8-8.5 lbs finished.
Thanks for the information. ;) Cata |
RE: MVVS.91 Break-in Prop/Final Prop
A 16x6 or 15x7 will do fine
Charles,
I stand by Pé in his general use prop recommendations. For break-in, however, I would prefer a smaller, higher pitch prop. I use 12.5x8 Bolly Clubman for this engine, but any 13x8 would be fine too. It will carry your model with authority. |
| All times are GMT -8. The time now is 04:32 PM. |
